BW-12D1S-U
    BW-12D1S-U
  • Fastest 12X Blu-ray burning speed and best burning quality by OTS technology
  • USB 3.0 doubles transmission speed compared with USB 2.0
  • Magic Cinema technology enables Blu-ray 3D entertainment, 2D to 3D conversion, DVD upscaling
  • Diamond-Shaped Design realize aesthetics of technology
  • BW-12B1ST
    BW-12B1ST
    • Drag-and-Burn: three simple steps to burn
    • Disc Encryption doubles the security with password-controlled and hidden-file functionality
    SDRW-08D2S-U
    SDRW-08D2S-U
    Burn disc with enhanced data protection in just 3 quick steps and intuitive Disc Encryption lets you do this easily
    • Elegant appearance embody the harmonious marriage of technology and aesthetics
    • Drag-and-burn interface accomplishes entire jobs in three easy steps
    SBC-06D1S-U
    SBC-06D1S-U
    • True Theater High Definition technology enables breathtaking, unsurpassed HD visuals using an innovative suite of video enhancement and optimization tools
    • Ergonomic, user-friendly design that can be placed either horizontally or vertically to save on space
    • Robust case eliminates risk of scratches and other damage to media
    SBW-06C1S-U Blue
    SBW-06C1S-U Blue
  • Extreme 6X Blu-ray writing speed
  • Drag-and-Burn: three simple steps to burn Disc Encryption doubles the security with password-controlled and hidden-file functionality
  • DRW-24B1ST
    DRW-24B1ST
    The ASUS DRW-24B1LT / 24B1ST is capable of reading and writing data on DVD±R/±RW, DVDRAM formats. It is a power saving drive and allows you to permanently delete the data on rewritable discs. This provides you with flexibility and efficiency in terms of multimedia data storage and sharing
    Video
    pre pre
